1 - 20 of 21 Posts
1%ER VIP
Barkers
PCV
FCI
Stage 3 hot cams
+3 TB
12:1 cp pistons 105mm
Springs
Head bolts
Head port and polish +1 and valving
Thoughts on 11.5:1 vs 12:1 please
Thats exactly what I had. I now have a +5 crank also. If your going from stock to that it is gonna put a smile on your face for sure!
1%ER VIP
Awesome! Can anyone recommend a bad ass builder??
Dude, that thing is gonna haul some a$$!!
Who are you having do the head work?
2008
Barkers
PCV
FCI
Stage 3 hot cams
+3 TB
Springs
Head bolts
Sounds like a winning setup! I don't have a preference on your two piston options; although, a lot of riders thing you need high octane with 12:1, but in my experience pump fuel works just fine especially in Kentucky. I'd suggest talking to Colorado700R he can set you up with a good builder.
KB Motorsports
1%ER VIP
Yea I definitely need to be able to use pump gas! The race fuel is not practical for me :(
So the 11.5:1 i suppose is the right choice then
Racers edge I went with Kenz Cycle but if I had it to do all over again I would go RE for sho. Believe me you will love it go 12.1 piston tho no 11.1 please
Also does ur pc5 have the timing curve with it. Cause thats like 3 hp for sho
1%ER VIP
I don't know if the timing curve comes with a PCV or not. Is that the auto tune?
Yea but then I'm going to be limited to running race fuel with the 12:1 tho.
I spoke to Kenz and racers edge to get estimates and what not, I'm glad u mentioned them
I ran a 12:1 on 91 octane with no issues in Missouri. I am right around 1000ft.
1%ER VIP
So if I run 12:1 with std bore 102, like the 11.5:1
Will it yield more power and run pump gas reliably and efficiently??
What cam were you running with that 12:1 piston?
1%ER VIP
Discussion Starter · #14 ·
Stage 3 hotcams is what I will be running
I ran two different cams with that piston, first was an X4 then later I switched to a Webb 4.
Yea I ran 91 to on my setup but I tried to put atleast 2 gallons in a 5gal jug. Really I couldn't tell what it ran better on until I put some MR9 in it
If u go RE ported head with a good cam 12.1 piston also the new pc5 with timing. Your bike will put out some really good numbers atleast 62-65hp guarantee
Ridin High.....
damn, i guess i should have tried 91 or 93. i ran 100LL for a while and had no issues. then just ran straight 110 that i brought home from LS.
i had RE +1, web4, 12-1cp, +3tb, fci and force4's. made 70hp/50tq at LS
100+ octane was reccomended from RE so thats what i ran. at 1100 elevation. good to hear you were able to run pump gas with no issues.
how much do you weigh? and what gearing do you run?
i have a 102mm 12-1CP forsale now by the way if anyone is interested.
My build was almost the same as yours, only difference was my head was done by Bo and I ran barkers, everything else the same, the first year of the build I did run an X4 cam though. When I did my build, this was before the tech piston came out I checked with RE and they told me that the 12:1 would be fine on 91, that's why I ran it. It was a shelf piston so the true compression would probably been slightly lower. I ordered the piston through RE. With my build I put down 73 at LS but I had switched to the 14:1 by that time. I am in the middle or doing a 770 13:1 build on it now.
I weigh around 160 to 170, bounce on that quite a bit. Rear gearing is stock and front I swap between stock and 15 depending on what I am doing.
Ridin High.....
im in the middle of a 105 and 14:1 swap as well. so i hope to see a good improvement at LS.
RE may of told me to run higher octane because im a lil heaiver guy (200lbs+).
loading up the engine more (more weight) gets me closer to detonation with this setup.
I may or may not of been fine of pump gas, was too scared to find out...
1 - 20 of 21 Posts
