whats up guys, i was doin a lil reasearch online and i found some hc pistons for pretty cheap. i was wondering how hard is it to replace the piston. do u have to split the case, or just remove the whole cylinder. is it ok to put a new piston in without a new rod?
No head milling is required, stage 2 cam needs spring kit, the center valve guide (intake obviously)may need to be shortened a hair.
Yea with the Stage 2 cam you will probably need to shorten the center intake valve guide. With the increased lift it could cause the spring retainer to come in contact with the guide seal.
Wiseco pistons are forged.
