How much more fuel should I add when I install my 11:1 and stage 2 hotcam? I don't hav access to a dyno so I can't use that. I'm gonna be installing them tomorrow so any help would be great.
Run 93 octane if that's what your asking. If your asking if you need to rejet I don't believe you will need to.
I have the PCIII. I already know to run 91. I just need to know how much more fuel I need to add to my fuel map on top of what it is set for the big 3.
usually with stock bore and just changing the cam....the piston will make the engine run more efficiant I wouldn't change it if your worried about it get it dyno'd
So it shouldn't make a difference?
