just put a hot cam stage 2 on my 02 raptor 660, plus i did a port and polish and now im running with the lid off........what jetting should i use?
Someware around 165/170(ish) mains, # 25 pilot's & after market needles 1/2 way (stock setting). See what that does for you..
Whats your elevation and do you have an aftermarket exhaust? I have a stage two cam, port and polish, 11.1 compression piston, no air box lid, full exhaust, and 3500 elevation and im running 165/170 mains, 25 pilots, and the clip on the stock needles two notches from the bottom and it runs pretty damn good. Hope this helps. Good luck =)
