21 - 40 of 196 Posts
Discussion Starter #28
27 Notice the openings in the front. You must guide the wires etc out of there prior to pulling it away and around the stem. Lastly there is also a cable that runs through this you can just slide over.
Discussion Starter #31
30 Exhaust side of the business....again both have different clearances....pay attention to detail. Also you will get some oil that comes out this side when removing it. I would toss a rag over the pipes and oil tank to help with cleaning.
Discussion Starter #32
31 Both of these plugs come out. One is 6mm and the other a whopping 14mm. You can skip the tool if you want and use the other end of your spark plug tool and turn out in and out by hand to save a few bucks.
Discussion Starter #37
36 This is where your camshaft sproket is located. It's held on again by 2 8mm bolts. It will seem "STUCK" but it's only because an "O" ring is holding it in place. Wiggle it out to reveal what's behind door # 3 8)
Great write up, Thanks!
Reactions: 2011PW
