1 - 20 of 134 Posts
Since there are no write ups for how to change a clutch, I guess ill make one for all the people who dont have the manual.
First off, you want to let the engine cool down if you were previously riding. ***MAKE SURE YOU SOAK THE CLUTCHES AT LEAST 1 HOUR BEFORE INSTALLING*** Now would be a good time to change the oil like I did or you jack the right side of the quad up to get the oil to the other side and plan on buying: Clutch (of course), Clutch Cover Gasket, and Coolant (50/50 mix or dilute the full power stuff).
1. To start we either want to drain the oil or jack it on its side, up to you, next you want to remove the 2 coolant lines going into the pump, have a pan ready because alot of coolant is going to come out in this step. After you have removed the 2 coolant lines from the pump, remove the 5 allen head bolts from the pump and place them in order (they range in size I believe). After removing the 5 bolts, carefully full the first part of the pump off and place to the side, next remove the rest of the pump, be careful the gear on the back is plastic, and place the pump to the side. Next you should see a small bolt inside and 11 more around the outside of the cover.
2. Remove the 12 bolts from the cover, you wont be able to get the one out in the bottom left corner, just dont lose it when pulling the cover off. Make sure you make a template of the cover and put the bolts in the order you remove them (once again they range in sizes). After removing the 12 bolts you need to remove the 2 oil lines, 1 on top of case and 1 beside the coolant line, after removing them you need to remove the clutch cable if you havent already. Now carefully remove the clutch cover and remember not to lose that one bolt you couldnt get out. It should now look like this.
3. Remove the 5 bolts from the pressure plate and set them aside along with the springs and now remove the pressure plate from the clutch. Now you can remove the clutches in one big pile. After removing them, flip them over and in the 3rd friction plate there will be a cushion plate (Number 8 in the diagram) dont lose it, it doesnt come with a new set. Now remove your clutches from the oil, you should have 8 friction plates, 2 with part number from yamaha ending in 01(Friction Plate 2 - #5 in diagram) and 6 ending with 00(Friction Plate 1 - #7 in diagram). You first want to install Friction Plate 1, next is Steel, next is Friction Plate 2, next install cushion plate(#8 in diagram), next is Steel, Friction Plate 1, next is Steel, Friction Plate 1, next is Steel, Friction Plate 1, next is Steel, Friction Plate 1, next is Steel, Friction Plate 1, next is Steel, and finally the last one is Friction Plate 2.
4. Now we can reinstall the pressure plate, make sure you line the arrow up with the punch mark in the basket.
5. Now is time to install the new springs if you bought them, put the bolt through the spring and reinstall to pressure plate and tighten. After installing that now it is time to remove the gasket from the cover and the case. New youll want to remove the lever shaft from the case, all you have to do is remove one bolt on the side(Dont lose the copper washer) and remove the shaft from the case. After doing this, put the gasket on the case side, put the bolt in the lower left corner of the case, and reinstall the case to the motor. Reinstall all bolts in the correct order, dont mix up lengths and tighten them to 7.2 ft lbs. Now were ready to install the lever shaft, first stick it back in the case and turn it all the way clockwise until you can move it anymore by hand, now carefully pull it out 1/2" and line the marks up now (A to B in the diagram) now that the marks are lined up it should be very hard to move the lever clockwise by hand, meaning it is trying to engage the clutch now, dont forget to reninstall the spring to the lever and reinstall the bolt.
6. Now you can install the clutch cable and adjust till you have 5-10mm of freeplay. After installing and torqing all bolts you can reinstall the water pump (Once again becareful of the plastic gear and o-ring gaskets), install the bolts in the correct order and tighten. Now reattach the oil lines to the case and reattach the coolant lines to the pump.
7. Now you are finished installing the clutch you can change filter and add oil if you drained it or just set the quad back down if you tilted it, now remove the front grill and fill the radiator with coolant 50/50 diluted. Start the engine and carefully watch the cover, oil lines, and coolant lines to make sure nothing is leaking from anywhere, if it is, fix it. Shut the engine down and check the coolant in the radiator again, fill it back to the top and top off the coolant resevoir, run the engine for a little bit and check the coolant levels again, if they are good, your done and ready to reinstall the grill.
8. Congratulations, youve just installed a new clutch and are now done. Go RIDING!!!
Nice write up :thumbsup:
Couple of tips I wanted to add; it helps to rough up the new steels a bit with sandpaper or steel wool. I usually soak my new clutch plates overnight the night before using fresh atv oil.
When tightening down the new springs do it gradually and use a star pattern the same way you'd tighten a 5 lug automotive wheel. This keeps any one spring from binding up.
Nice Write-up. Next time someone does it, take pics of it, and post them up, please.
Discussion Starter #4
Lol, I wrote it after installing the new clutches :p
I'll take some pics. I've got to put a new one in mine since I burned up the old one.
Guys I'm sorry I got so excited about puttin the new clutch in and forgot to take pictures. Anyways I'm always sticking with a Barnett Dirt Digger clutch because... Man this thing is fuckin amazing.
I'm 80% sure that I've got at least 1 broken clutch plate right now. I'm going to try to get a new one put in before my ride on Memorial day, but if not I've really got to get one in before the Silver Lake Rally in June. If I'm the one who ends up doing the work I'll snap a few pics.
Discussion Starter #8
It only takes like 2 hours to do it and memorial day isnt for like amost a month
My quad makes a rattling noise when you give it gas in idle and at low speed, it shifts hard and sticks, a real bear to get in and out of reverse. I'm assuming it's the clutch... Is it usually just the clutch plates? Is there any other hardware you all reccomend? The budget is gone do to Foreman and Jeep problems - I saved so much buying used :'(. So anywho make my day and tell me plates are all I need. I've got the Clymer and your write up is great. Any difference between the 40.00 plates and 80.00? :help:
Any pics yet ? I ordered my GYTR clutches and GYTR clutch basket today. It should be in by middle of next week. This would be my first time doing the clutches on my own and if possible I would like all the minor details explained to avoid having to deal with the down time.
For those that have done it before, I'm sure its not that hard, but im sure there are things that are overlooked or taken for granted that some of us are not going to know what to do. thanks guys
would it hur them if you didn't soak them first? and why soak them ? I have mine apart now I just never done it before so I didn't know about the whole soaking thing.
whats the best clutch and springs for the price, something better than stock
yea i second that ? what is ?
well, over x mas break i will be rebuilding my raptor, and along with that i will be installing a new clutch.
Ill do my best to come thru on the pics
The raptor uses a "wet" clutch. If you don't soak them first they will drain your oil tank by about half a litre (quart) among other things.
what happens if u forget to put the cushion plate back in? rebuilt my brothers clutch and we forgot to put the cushion plate back in, he threw it away and now have ordered one on bikebandit.com 12.00... whats the purpose of this plate? we both rode bike and it shifts fine and engages in all gears. so whats the purpose. please reply, as we are tearing it back apart to install, over the weekend..
In the frame?
My buddy hasn't been able to remove his clutch cover with the motor in the frame? Is there a trick to it? Or did he give up to quick?
1 - 20 of 134 Posts
