I think I have narrowed my rich problem to the injector. All sensors check okay by the mannual. Could you guys help with the proper method to test both on the bench and on the engine? thanks Mike:-*
Discussion Starter #3
thanks for the reply, I know that is a common problem, and it would be a easy fix but it checks okay on the voltage and ohms. I wished it was the problem. thanks again mike
Discussion Starter #5
Aaron I had this problem when it was bone stock, I went ahead and installed a full exhaust dobeck k/n no air box lid, because I had plastic and tank off . I cannot take enough fuel away at low speeds to run lean it still wants to black spark plug, It should be lean,
