my neutral light stopped working yesterday, is it as simple as a blown bulb or just a bad wire, how do i tell
if it is bulb where can i get a new one
if you have one of them 3dollar test lights,you can check it that way'' i use my test light on everything. there a must have for your toolbox8)
+1 on test light. It has saved me hours of trouble shooting time.
Does you reverse light work, if so you should have power at the neutral light unless the brown wire is broken between these two lights, which would be highly unlikely.
The brown wire in the neutral light should have power at all times, the neutral light is turned on by the neutral switch below the drive sprocket, This switch grond the circuit, a light blue wire is attached to the switch.
If the switch works and you have power at the lights, most likely you have a blown bulb. If the bulb is'nt blown, then you may have a bad connection at the switch or a broken light blue wire...............
