I have the cases split and the crank is still in the left (flywheel) side. The crank is bent and will be replaced... How do I get the crank and bearing out of the left case?
Discussion Starter · #2 ·
Surely I'm not the only one to swap cranks...
The bearing on the left case side is interference fit into the case, without a press, is there anyway to get this out?
If it has the same threaded holes on the case as a 700, find two long bolts and run through the case pushing against the crank. Run them in evenly and it will push right out. I believe it was 8mm thread.
Yep you use two bolts and push them out
