i dont know if there is anything on here with just how to posts. i tried to search and with no luck i decided maybe this can be sticky'd. it sucks to have to search for hours what you want to find so here are some easy ones that i know of most will already be sticky'd.. ive been through easily 150 pages in the catergories.. also if ppl want to join in with write ups they know of..
how to paint your plastics with bed liner- http://www.raptorforum.com/forums/showthread.php?t=65967
How to replace the starter one-way bearing- http://www.raptorforum.com/forums/showthread.php?t=60905
How to: change the clutch basket- http://www.raptorforum.com/forums/showthread.php?t=35229
how do clear tube method on carbs- http://www.raptorforum.com/forums/showthread.php?t=538
how to get rid of your reverse limiter- http://www.raptorforum.com/forums/showthread.php?t=11734
how to do the flipped link mod- http://www.raptorforum.com/forums/showthread.php?t=24958
How to Adjust Your Shocks- http://www.raptorforum.com/forums/showthread.php?t=35290
how to stop the squeak squeak- http://www.raptorforum.com/forums/showthread.php?t=53635
how to put yfz rear shock on your 660- http://www.raptorforum.com/forums/showthread.php?t=73859
how to put a 700 shock on a 660- http://www.raptorforum.com/forums/showthread.php?t=65714
how to change clutch plates- http://www.raptorforum.com/forums/showthread.php?t=8688
how to do an oil change- http://www.raptorforum.com/forums/showthread.php?t=46
how to remove pb sensor- http://www.raptorforum.com/forums/showthread.php?t=9356
how to replace stator-
http://www.raptorforum.com/forums/showthread.php?t=30801
thats it for now and again i know most of these are sticky'd but i think it would be easier to just have 1 thread with tons of write ups
We have such a layout for the 700R sections, thanks for taking the time to start one for the 660.
For all members looking in, if you find a thread you feel is particularly helpful please post a link to it here along with a description of it's content as phillyrappy did in the first post. We will sticky this item and hopefully it can serve as a gateway to other threads.
Please refrain from extraneous posting, as I'd like to keep this thread as on topic as possible.
Well it's in the 700 archive section, a section designed so that we didn't have 20 stickies at the top of each section ;) so that's why it's not a sticky itself.
But that's fine, most of the information should transfer over except for the location of the items being wired up and the mounting locations for the ballasts.
Ya i figured the lights should be pretty close to the 700R one's so i figured i post it if someone ever wants to do it on the 660 :Thumbsup:
