1 - 20 of 33 Posts
Hey guys just wanna see what u guys figure this thing should put out.
The builder figured about 75hp. Now A Dynatek Ign and a larger injector Would these items bump it up .Oh and 100% C12
Is it just me or does that cam seem really small for that build?
That build would deserve atleast a Hotcam stage III, but I would go with 50/50, Web, or custom grind for that build. Hotcam stage 2 is basically for guys with big 3, but no piston mod, or head work. The ignition would bring a HP or 2, but won't be too noticeable while riding.
ok Easy fix new cam it is . So which cam would give me the most , and still be usable for trail/Dunes.
Conventional wisdom on these forums would say so. Then again this and other forums seem to think that as soon as you do any kind of porting on a head the build needs a 5050 or a web4.
Discussion Starter · #14 ·
So with right cam and 565 injector hp closer to 80???
Clean 700 Raptor
At 79 hp at sea level with my mods
Very true. I go by what I have read here on the forums and in all honesty do not know much compared to alot of other members on here. Just you don't see many HC2's in a build that has +2 valves in it.
Not singling anyone out in particular, the sentiment is too widespread for that. I would agree that a stage 2 hc is on the small side for the build based upon the metric of what is common on internet forums and that he would see greater peak hp and torque with a more aggressive camshaft. Whether all situations call for camshafts of the caliber of the 5050/web4 which are so commonly recommended is another question.
Cola Crew
I like to see that I'm on par with my build at 78hp.. Some on here have said that we need a new builder because we are not pushing big #'s.. And that n/a builds make 90hp all the time, this maybe true but I have not seen it.. I like the 5050 and the web4 But I run the X4 and it works very good..
My Sig is out of date
Sparks BC X6
PCV
PRO Design Intake
Dynatek Ignition DL curve
+3mm TB
X 4 cam
Ported Head +2+2
5mil Crank
13.25 to 1 cp piston
105 BIG BORE
Who makes the 5050 or web Cam.
1 - 20 of 33 Posts
