:mad:was changing the oil and i think i stripped the oil tank plug out, cuz a thin strand of metal wire came out that looked just like threads :'(, now I am up shits creek unless the part I stripped is not the part of the tank that costs $227, F*ck :mad:
It is part of the tank, but you don't necessarily need a new tank. A few options are.
1. Tap it out to a larger size.
2. Weld and retap.
3. Helicoil, kits run about $50 for the tap, install tool and 6 or so inserts.
4. 2 part epoxy, not the best fix going, but an option.
5. Look in clasifieds section for a used one
nevermind, found a aftermarket oil tank that holds more anyway plus is cheaper :eek:
