Just installed lte, pc, (pc map also) and filter, now when it is started it runs for ~10 secs then dies. So restart, hold the gas just enough to keep it off idle and runs pretty good. It has a slight miss sometimes. No computer codes. I can't ride it so I dont know how it does under a load. Im in Denver so would the high alt. have anything to do with it? If the PC map is rich would the elev. just make it richer? And would a "bad" map keep it from running right (idle) if it was just slightly rich? Could it be the map sensor connection, or would i be getting an "check engine"?
