1 - 10 of 10 Posts
I need a case saver.... but i have the 15th front sprocket.... I bought a case saver "Epic" was the brand name... they told me it would fit on with the 15th front sprocket BUT it will not.... So i would like to hear which case savers you all have on that fit on with the 15th front sprocket...So i can get one.
Thanks Plattner
i order one from rocky mountain atv 30 buck pro design it works great on renthal 15 tooth :thumbsup:
What does the case saver do (other than "save the case").
Thanks Plattner
Drop me a PM if you would like to sell the Epic one
TIA
Most aftermarket ones are billet so they look better then that big plastic piece we have.
IMHO, now it's mostly about bling and style - unless you're running undersize chains and/or mondo power for racing. Chains used to be a LOT weaker and would break - sometimes terminally damaging the case. Personally, I have not seen a properly maintained chain break in over a decade.
My 15 tooth front sprocket is that "off brand" one that rocky mountain sells.... i only bought it bcs they didnt have any renthals back when i got mine.... SO i think i am going to order the renthal and see if my EPIC case saver will fit and if not i will have to get something else.
Thanks guys... anymore suggestions on a case saver to fit on over the 15 tooth sprocket i have now would be greatly appreciated..
Thanks Plattner
Got my 15T on with my epic case saver. Just need to shave off alittle from the inside and you'll be good. Might take you about 10- 15 mins of your time but will work great with no problem. :thumbsup:
VelociRaptor said:
The factory case saver behind the plastic cover does just fine, I just trimmed the factory bolts shorter to run it without the cover :thumbsup:
I still run mine too, although I had to trim mine a little to fit with the 15t.
1 - 10 of 10 Posts
