2005 660. Stock carb. I`ve had the quad a year. It runs great.
Completely stock besides pro form air filter, air box lid on.
Both carb drain lines started leaking . Not dripping ,flowing.
It was still running great even with the leaking .
I figured float must be stuck. Removed carb.
Previous owner stripped most of the float bowl screws real bad.
I completely disassembled the carb and cleaned everything.
All stock oem brass parts were reused . Only new o rings.
I also replaced both floats. Set them to 13mm height.
Reinstall carb. Starts great. Smooth idle. Sounds good! I let it get up to 185. Turn the choke off and it dies .Restart it and when i rev it sputters and back fires. I rode it and losing power and sputtering. It won`t run with the choke off. Is my choke not adjusted ? Floats? Feels like secondary carb is not getting fuel? Suggestions? Thank you.
