Hey guys, got the carb back on, started it with choke and was excited cause it sounded perfect! Let it run for a little then turned off choke and it starts idling super high. What can be causing this? Thanks
Discussion Starter #3
Man if it's only an airleak that's good news, I'll go spray with carb cleaner and see if I can find anything.
Discussion Starter #4
Would having the throttle assembly open pull air by chance? Needed to make a gasket before closing it up and ran out of time
I'm not 100% but I do remember reading that it could suck air through there. (Assuming your talking about the part on the left carb). Do you have free play in your throttle lever? Don't want something small to be the issue and you are chasing your tail on it.
Yes it will pull in air from there.
