Hey Guys,
Anyone have any recomendations for re-mounting the ignition key after putting on Pro-Taper bars? Since it took away the stock bracket during install,l I want a clean way to re-mount it (other than zip-tying it to the brake lines). Thanks
I cut three holes in the top front grille mounted the Neutral reverse and over heat light there and moved the ignition to the opposite side fender same spot as the reverse on my 660
I can take some pics for you later when I get home from work if you want
Thanks for the input. I did eventually find some articles and instructions w/ pictures online after a little searching. Like the idea of the reverse relocation kit, taking your hands off the bars to shift in reverse seems a little akward??
