1 - 10 of 10 Posts
Is there anything else i can do to improve hp?
Already has full yoshi exhaust, jetted, aluminum airbox w/ hi flow kit, dynatek CDI, mild porting, stage 2 cam, and 719 stroker kit
where's the nearest dyno to north central ohio??
you could always go with a 780 kit
i have been there... there isn't one in tucson...
FCR carbs, dual exhaust, bigger air filters/remove airbox, more aggressive porting, more aggressive cam, bigger bore, higher compression, longer stroke.
Also turbocharge, supercharge (someone's working on this), nitrous, alcohol/methanol/nitromethane, oxygenated fuel, or an ALBA inspired rocket will boost the number on the dyno.
Now if you want to go faster you can make great gains in tire/sprocket/suspension setup or shed some pounds (on the bike or yourself ;)) without increasing hp.
Looks like Phoenix and the surrounding area is where they all are, closest one in TX is 317 miles or so in El Paso. Basically, plan a day trip or do it yourself. ;)
1 - 10 of 10 Posts
