i just purchause Rappy 350 3 months ago. right now i feel it little slow for me so what should i add accessories to increase power into racing power! also i use it to jump, that mean i need increase power on low end. what should i buy accessories to change my atv into racing power?
exhaust..re-jet...k&n air fliter... maybe a new high performance piston .. new cam...if you really wonna put that much money in it....the max hp for a raptor350/warrior is about 48-50.... :thumbsup:
Cheap way to add power remove the baffle oh so easy then turn in your air/fuel screw in a quater turn.And buy a 12 tooth front sprocket for less than 12 bucks and that will add a good bottom end gain that is with a few mph off the top.Or if you have around 400 bucks to drop do as balzer said get a slip on and re-jet and maybe a cam a cam ia around 150-200 bucks slip on that i would rec is the HMF 250 is a good going price it comes with the needed jets.
