Yes, stock is 520mm wide, so as long as there's enough links, which there should be.
Agree, the chain is compatible and is actually a really good one. You will definitely need to cut it as it looks like that one is 124 links and raptor takes 98 (i think?)
@Sixpack577 believe it or not chains are actually sized in SAE. 520mm would be over 20 inches.
Reactions: Sixpack577
lmao, belive it or not I knew that, I just worded it really bad.
Thanks for the correction.
I also work in a machine shop, with small numbers every day...so that makes it even worse, lmao
Man, one decimal point can ruin your whole day! Hahaha
I thought it sounded odd, your usually spot on
  • Haha
