I know the process has been talked about before. Is it worth polisishing stainless steel before install. i mostly ride on trails so they do get dirty, unlike the dune riders.
I have some experience with polishing and would deff. not recomend you doing that since you bike will see water and dirt, once the pipes gets hot they will loose the shine and as soon as you hit anything wet while the pipes are hot, they'll get brown and there goes all you work down the drain in a matter of seconds.
What you can do is though, get some ceramic header paint that requires baking @ around 400-600 degrees, that may hold for some time.
I may do that in future, so I'm searching on good quality paints.
JW
