the flywheel on my 05 660 was damaged when my crank broke. i purchased a used flywheel to replace it from someone on the forum, but it does not work. it is made completely different and the bolt pattern to install the 1 way bearing is even different.
im assuming there must be a year or serial number break. what will work with an 05? the one i need is on the right.
