Hi all, im gong to need to clean my caarb this weekend because the jets are clogged, my question is do you suggest i clean out the ones i have with cleaner and copper wire or should i just get new ones seeing how they are only 7 bucks for both and also am i going to need a new gasket for the carb bowl or just use the one thats on there, thanks guys
New works too if you don't mind spending the money. Just make sure you buy the OEM jets and not cheap knock offs. Then clean the old ones and keep for spares to change out if it happens again.
They're $3 a piece at Yamaha dealers. Get a new gasket too, the last thing you want is to put everything back together and find out it's leaking.
