im working on a buddys 04 raptor660 with billet adapter and k&n filter with outerwear NO airbox lid, white brothers R4 full exhaust
currently jetted at 148/150mains...22.5 pilots..4th groove on the needles not sure on the mixture screw...im in california SEA LEVEL
i cleaned out the carbs, installed new pilots...replaced the float valve seats and the o-rings that go around the adapter that the main jet screws into
it runs pretty good but backfires when i let off the throttle and when i give it some throttle it pulls fine
any ideas what could be wrong? the bike sat for over a year....
With an open air box you will need #25 pilots, aftermarket needles with the clips at half way and 160 to 165 mikuni mains...........
Back firing when you let of the throttle is a Lean pilot / idle circuit. Put #25 pilots in with the fuel screws around 2-2.5 turns out.
Think of it this way. Changing the pilot jets is a coars adjustment. The fuel screws are the fine adjustment. If you have the fuel screws under 1 turn out then you need to step down 1 pilot jet size and reset the fuel screws to 2 turns out. If your more than 3 turns out your lean and need to install the next size larger pilot jet. Then reset the fuel screws to 2 turns out and fine tune from there.
By looking at your main jet size your running a dynojet kit.
Your mains are fine. Dyno Jet 148/150 is around the same size as Mikuni 165.
Since it has set for a year make sure the carbs are spotless. It doesnt take a very big pice of junk to plug up a pilot jet.
Sounds like you have DJ mains - and 148L/150R will be fine. YOu should have 25 pilots, but try opening up your fuel screws a half turn each and see if the backfiring gets better with the 22.5's.
i started it up today again and went up and down the street real quick and didnt backfire...yesterday the engine might of got warmer and today i just went for a quick spin
if it needed a valve adjustment would it backfire? everything seemed fine other then the backfiring it was doing yesterday when i let off the throttle
jetting has been the same, i didnt change anything other then just installing new pilots to avoid risking the old ones being clogged even after cleaning them
It should be more apt to backfiring when cold because it would be leaner at a cooler temp. Idealy you should have a slight soft poping or woof sound when letting off the throttle. If you getting loud, hard, sharp cracking like a fire cracker then it is lean.
As for the valves I dont know I havent ever ran mine out of spec. I usualy check and adjust them before it gets to that point.
Backfiring on deceleration is simply due to being a bit too lean on the idle (pilot) circuit. Turn your fuel screws out 1/4 to 1/2 turn each... if this doesn't help, or you're already at or beyond 3 1/2 turns out, then you need to up to 25 pilot jets and start the screws at around 2 turns out.
