1 - 11 of 11 Posts
i bought a 2002 660 about 6 mths ago. its running a 146 and 148 dynojet. i ordered a GYTR kit and will be rejetting. im running
full yoshi
open airbox
stage 1 cam
im guessing to go with a 160/165 and step up to a 25 from the 22.5 on both carbs as well as 3 turns out. i have gathered this from this excellent forum.
does this seem reasonable?
what about the needle c slip? its currently on the third?
thanks ahead for any input.
Dunno if this is any comparison, but Ive got stock exhaust without spark arrestor, open lid, k&n and I jetted mine with 150/155 and 30 pilots. Turned idle mixture screws out 2 turns. Works awesome.
IMO-for you-Sounds good on the mains, I would go 30 on the pilots (cause you can adjust from 25-30 with the screws) 2.5 or so turns. If I remember correctly-the clip from the factory should be in 3rd position on the needles.
good luck
thanks
do u know the ratio of turn outs to pilot size compensation?
all i know is that the stock is like 22.5 and most people go up to a 25. but it makes since to do minor adjustments with the air fuel mixture.
HP
If you're over 3-3.5 turns on both screws it's time to move up a pilot size. 1 and under time to drop a pilot size.
25 Pilots and Mikuni 160/165 mains sounds like a good start. GYTR kits are numbered like Mikuni jets, so you're okay with an open airbox. May be a tad rich on the low end, but it's better to be a little rich than lean.
~Brian
how do you go about adjusting low and high end of the RPM curve separetly?
i mean is it the needle setting that adjust the low end or pilots / jets etc...
thanks
HP
Maddog helped me to sort mine out, i am running duel pipes and K%N(no airbox), I am also running 160/165 mains with 25 pilots, GYTR needles on the second clip and mixture screws 2 turns out. It all depends on your elevation and then each rappy is different. Be prepared to go through the process atleast 3 times.
Pilots controls the lowend, needles the midrange and mains the top end - If i have everything correct
1 - 11 of 11 Posts
