Ok so im just waiting for my header, then im going to jet my carbs, but what size main jets do I use and where do I set the clips on the needles?my elevation is 0-3,000 above sealevel. I'm going to use the #25 pilot jets. I have a pro-flow K&N kit with no air box lid. Also I have a full FMF exhaust system. So if you guys could give me a starting point on what main jets to use and what setting for the clips on the needles it would be a big help. Thanks
at 1000 ft or lower, i would go 160/165 on the mains. another thousand feet up, go down a size on the mains. you dont really need bigger pilots... This is just a starting point. You will have to check your plug to make sure you have it right.
