So I got my 01' engine rebuilt because of gear issues. I put it all together yesterday and everything seems to be in the right place lol (First time putting it all back together) So I have a few questions before I start it and blow it up again.
1. What are some of the general things I should check before I start putting the oil / coolant in it?
2. Once I put oil in it and start it up, what's the easiest way to tell if the oil pump is moving oil through the system? (Same with coolant)
3. I'm missing the O-Ring for where the throttle cable goes into the carb, Can I pick up another O-Ring at a hardware store to fit it? If so, what's the correct size to fit it?
I'm kind of a noob at mechanics, I just like to do it all myself even though I have no prior experience so just throw out some things I should check so I dont seize it up. WISH ME LUCK
