1 - 2 of 2 Posts
So i just got my carbs back from the fuel screws being drilled out and putting new ones in, cause the ones i had wouldnt move. OK. So i put the carbs back in and i have the screws out 2 1/2 just like hmf tells me, but there gay so who knows. and i had also put a 145 in left and 150 in right just like it says. I have the hmf sport series slip on. I also have an prodesign air filter, air box lid on. I put the carbs in and put everything back together. I started it up re did the idle adjustment screw. THe bike will sit for a couple mins and run, and out of no where it will shut off, If any one has suggestions plz post.
First play with the idle, it's probably stalling after it warms up.
If the idle won't adjust enough, use the throttle cable adjustments.
1 - 2 of 2 Posts
