1 - 10 of 10 Posts
Jets are all factory, same goes for needles, factory exhaust, factory airbox and lid, UNI slip on filter. I set the AF screws to 2.5 on each carb. Bike starts up fine and will idle for a given amount of time then just die, also the rpms are a tad high until i adjust the idle screw but this seems to make it die more often as i lower the idle) . Most times it will start back up right away, a few times i need to give it a little gas, But it does always start.
Just looking for a little insight, Ive never been all that great with carb problems.
Start by giving the carbs a thorough cleaning internally, all jets and passages, make sure you rod out the jets, and pay special attention to the pilot jets..............
Already did that. Bought a carb kit and replaced everything that came in the kit. Anything that wasnt in the kit was cleaned. It runs fine while moving, imo its either a float issue or AF issue.
Did you clean or replace the pilot jets, if you cleaned them, how did you clean them..............
all jets were replaced, along with float needle and seat, main needle, o-rings, idle screw/spring, AF screw/spring/o-rings. It was a complete rebuild kit.
Were the pilot jets the same size as used previously, stock is 22.5s but 25s are much better suited to the Raptor.................:)
1 - 10 of 10 Posts
