1 - 20 of 27 Posts
Can anyone tell me if I can install a k&n air filter to a completely stock raptor 700 without having to get a fuel controller? Thanks!
If you keep the lid on, and just only change the filter type you shouldn't need to run a controller as you are taking in the same ammount of air, now if you change the intake throat (bigger) you will need to get a controller as you'll be running more lean.
Ya, you should be ok if you only get the replacement filter with the lid on but like krandall said, if you get any of the kits that run a larger filter ar anything like that then you will probably need a controller.
it's not worth it in that case, IMO, i'd just get a new stock filter, or clean the one you have, just the K&N with no controller/ intake kit, won't be really worth the $ you invested into it...i'd wait, get the controller, then intake, ditch the lid,and sparky..stick to stock filter for now if you can,...why do you want just the k&N?
.....I didnt know k&N made a drop in filter? How does it attach to the stock backfire screen? The stock filter has a bolt threw the middle and that how it attaches.....never seen a k&N like that...and if there is, its not going to seal for crap at the throat end!
The only way I am awhare of, comes with the adaptor plate, which is an entire intake system. I would not run an intake on a stock machine with no aftermarket map!
RAD700R said:
I do, just keep the lid on. The air/fuel mixture would be the same
hmmm, how does it attach?
would it be exactly the same? or just close enough not to matter?
cuz with a better air filter there has to be some extra air right/ if not and it doesnt make that big of a differnce untill you get the adapter and lid off, then why waste $ on a aftermarket, especially a k&N that's gonna hit your pocket for a couple dubs?
These things can use a controller even stock. Thats one reason the headpipe glows cherry red.
yeah i know. the dealer said it was ok if the headers glow it is normal. ive been around race cars for a long time and the only time they glow is when they are being rode hard or running lean..
Stock filter tore in a couple places b/c i cleaned it too much :lol:. I asked my dad to pick up another stock one at the dealer, came home with a k&n. So he mounted it up. In the instructions they said no fuel adjustment is needed to have this blah blah. So as long as you keep the lid on i think i wont make a differnce. So now im 1/3 the way there. One thing i didnt notice till I rode my friends 700 is that mine didnt have as good throttle response, nothing to notcible though.
the first thing i did was put on my B&E, and as RAD700R said i noticed a lack of throttle response right away, it would also hesitate, almost stall if i just pinned the throttle (it was fully warmed up).
Get a controller and it'll fix that.
Still wondering how just a k&N attaches to the stock setup? Doesnt make much sense to me? How does it seal at the throat? How does it go onto the stock backfire screen?
i believe k&n makes a direct replacement and of corse the bigger slip ons for more air... i have a blaster that had about the same setup for air filter and i had a k&n for it and it had the screw that went thru the middle of the filter... and also get a controller it will be about night and day diff. from stock.
check out k&n's website and look at ya-7006, it comes with an adapter
Exactly, which has an adaptor, which is essentially an intake!
"Can anyone tell me if I can install a k&n air filter to a completely stock raptor 700 without having to get a fuel controller? Thanks!"
.......this was the original question and anyone that knows what they are talking about WOULD NOT recomend running this without some type of controller! That is going to lean out the machine.
Hey all....so I got a 2007 700r with lexx slip on and weisco fuel controller....I just added the k and n plate n filter kit...put new spark plug in and went for a ride....plugs gold outside white in center....only went for a 15 min ride but went through all gears n was on it ....ran great def noticible diff but wondering if u guys got advise on what settings to change on fuel controller to get rid of the white center in plug....obviously more fuel but for what settings? All?
1 - 20 of 27 Posts
