1 - 2 of 2 Posts
I have an 03 a buddy gave me a K&n Filter Its the kind that replaces the original (same opening) Can I buy an adapter to hook it up to run without the lid or is that only possible with the filter with the two round ends? Thanks..
The correct way to do it is to use the K&N filter with the two flanges.
You could probably drill a hole between the two holes in the air box. Put a hole in the end of the filter. Make a plate that is a little larger than the end of the filter. Use a long bolt to hold the filter in place. It would kind of be a hoaky setup but it would probably work.
1 - 2 of 2 Posts
