I know this was talked about somewhere in here, but i would like to see who has all done it. Pics and kinda discribe how you did it. I'm would like to do this just need to know how. Thanks
I'm assuming your going to install the DRD to make room for the ignition. Simply fish the ignition down underneath the fender giving yourself enough slack to push it up through the hole in the fender. Take the plug supplied with the DRD reverse setup and drill a hole large enough for the ignition to slide through, take a dremel and make a notch to match the raised area on the ignition so it doesn't spin in the plug. Slide the ignition through the plug, tighten down the plastic nut and if you haven't already done it put the plug containing the ignition in the hole in the fender.
http://www.raptorforum.com/index.php?topic=10199.0
Yep, thats exactly how i did it too ;)
That's how I did mine also. I would consider pulling the front plastic to help ease the relocation of the key switch. Also, keep in mind, the switch will bottom out against the head light bracket.
Thanks guys, I thought it was pretty cool when I saw it.
