1 - 2 of 2 Posts
I am not "electrically" inclined. I get how to do the ground, but not the other part with the stator, do I need to pull the flywheel to get to the stator? Where even is the stator, I assume next to the shift lever? I know how to get to the stator on a sled, but not a Raptor... HELP... Thanks...
The stator's leads all exit the case and go elsewhere.
The wire that you want is white with a red stripe (the pulse coil + wire). It should go from the stator all the way up to the CDI (the computer, under the seat). Find this white/red wire, anywhere, remove some insulation from around the copper core and solder your other wire to it then tape up (best), or a clamp on quick-splice or tap-splice can be used instead.
Now, when you press the kill button, this will short the white/red to ground, the CDI will no longer see pulses from the pulse coil and will not generate spark pulses that go to the ignition coil - spark stops.
1 - 2 of 2 Posts
