After installing a Vito's jet kit with aftermarket fuel screws, I get a tiny leak out of one of the carbs. I changed the o-rings on the fuel screws, but it still leaks while it is running. Could the seats be damaged? I didn't overtighten anything. Just tightened until I felt tension, then backed it out 2.5-3 turns.
If the seats are damaged, is there a way to clean them up or smooth them out? Could I use a larger o-ring? I hope my only option isn't new carburetors.
