Any idea how to get the bolt off that the stock chain roller rides on. Bought two aftermarket ones (ebay and Motosports) and they both come with a long threaded bolt which seems wrong too exp since the bearings should not be running on a threaded bolt. is this piece part of the frame? Also does the chain always ride against the lower roller?http: //www.raptorforum.com/forums/images/smilies/huh.gif
07 350 raptor
Yes, it should NEVER touch the upper, unless you jump, then it might come close. I would take off the chain, and then reomve the bolts, and then the red rollers will slide off, along with the white plastic things...
Thanks,
The bolt does not remove the whole piece. There is still a hollow metal guide there that does not want to come off. tried unscrewing it and beating it with a hammer. Is this a piece of the frame? also how about the lower roller. Does the chain always ride on this.
