Sweet... i'll look for some of those then also.. Thanks!!The front Raptor 700R piggybacks from the 07SE/GYTR models and all of the 2008 and up Raptor 700 fronts will work.
Weren't those a-arms long travel though? Or did you have those 17.5" long elkas on something else?I used LTR 450 shocks on my Houser +.5" a-arms for a year till I could afford elkas. They were great. I had to slightly move my coolant resivoir to fit 700.
The LTR is also actually lighter than the Raptor 660 and Raptor 700, not sure what you're comparing them to as far as being too stiff, but on a 50" wide mx quad I'm not surprised the suspension is stiff to absorb the impact of jumps. Glad you found a use for them.They are too long for the standard raptor suspension geometry.
Noone is trying to tell you your wrong MD. Everyone knows your the fastest Googler around. I was speaking to the quality of the shocks. In numerous test and shoutouts, the LTRs were found to be to stiff. The added weight of the Raptor softens them up a bit. Anyway, thats my experience with the shocks in question. I hope Socal can use my input with or with out your blessing.It would be useful if you included that they were long travel a-arms when chiming in, as there is a difference in the application.
As I said;
Again however I wouldn't recommend mixing and matching shock lengths and travels. Your suspension will work best and be safest when your shocks are the proper length for the geometry of the a-arms. You have used 3 different length shocks on your Housers, you may want to find out what length of shock they are actually made for, and the next time you have them in for service you can have them shortened if need be.
Arent the yamaha 450 shocks shorter also? I thought they were since all the bikes seem to get a bit lower when using the 450 shocks. or so i read..I simply wanted to clarify for those reading this thread that your experience was not with standard travel geometry. Your post did not specify, so the casual onlooker could have easily thought that you had bolted them on to standard travel housers. I wanted to safeguard against someone buying a set of LTR450 shocks based on your advice then later realizing that they won't fit his stock or standard travel aftermarket a-arms.
The rest of my post was me trying to help you, I wouldn't want to see your ball joints bind up and cause damage or a failure of the front suspension because the shocks installed were too long or have your front end bottom out because the shocks are too short and spring rates aren't capable of coping with the added force of the different geometry.
Stock rezzy 700's are near as makes no difference 16", stock pogo 660 is 15.5", stock 04-09 YFZ 450 shocks are 15.75-16" depending on who measures.If I remember correctly, its been a while since I messed with stock shocks or the LTRs. Stock 700s are 16 1/2" and the LTRs were 17 1/4".
So basically the YFZ 450 are the only shocks that will work.. Well work the right way anyway with stock 660 armsStock rezzy 700's are near as makes no difference 16", stock pogo 660 is 15.5", stock 04-09 YFZ 450 shocks are 15.75-16" depending on who measures.
I guess my "2 inch longer" statement was too long, no pun intended. The LTR shocks are just over an inch too long for stock geometry 700, and just shy of 2 inches for the 660 if your LTRs measured 17.25.
I have seen people bolt up some old Polaris Predator and Honda/Suzuki 250R/400 4 stroke and honda 450R front shocks as well, and at 16.5" length on a 660 there were some pretty extreme angles on those ball joints at full extension. Some have run longer shocks with lowering kits though, not that I was particularly impressed with the ride quality (I didn't push them too hard) or the added stress on the mounts because of the kit's change in shock angle with respect to the ground.
