1 - 15 of 15 Posts
I remember reading something about putting in a switch to manually control when it turns on, can anyone refresh my memory or point me in the right direction. thanks :crazy:
Yeah, the sensor on the bottom of the radiator. The connector plug-in there has two wires. split the wires and run the switch parallel to the connector so both the sensor and the switch will work.
I just installed mine last night... it works great...
could you go a little more in depth, I have idea what I am doing when it comes to electronics. It sounds easy until I try it maybe a step by step. and what will I need besides the 12volt switch :3question: :help:
I got it, thanks man
:thumbsup:
yeah, makes it run cooler. I rarely hit the temp that the switch engages at. its 210 i think
put a switch parallel to the connector that goes to the bottom of the radiator.
Two types of circuit, parallel and series
Parallel is when the electricity has two paths to follow, it can go thru either the thermal switch and turn the fan on or thru the switch your adding to turn the fan on.
Series is when the power has on part to follow, if you added a switch in series you would have to turn on your switch and the thermal switch would have to be in the on position for the fan to run
I don't think you'll need to unplug the radiator, you just need splice the red/white wire.
In the picture #14 and #15 are in series, the red added switch is parallel to #15.
Awsome post Firstraptor :thumbsup: you made it to easy 8)
next to the front fender on the main frame.
1 - 15 of 15 Posts
