I have a 19' raptor, with stock exhaust , a k and n air filter and a moflo air box lid,
I purchased a Dyno jet 5 fuel and ignition control, but cannot find a map for my set up
I plan to purchase an exhaust system at some point, but, will runtime current set up for awhile.
Do I need to change the mapping at this point?
thank you for your help!
Have you looked through dyno jets website to find something close? Doesn't need to be exact...
Discussion Starter #3
yes,
unless i missed something, there was not a tune offered for a stock exhaust with a modified air box
yes,
Use Map 22-074-002 (Stock exhaust system GYTR Intake kit Airbox lid removed). That will get you pretty close if not a little on the rich side which isn't a bad thing.
I just installed my Power Commander 5 yesterday and noticed same issue. he maps available are quite limited. I thin that I would put the airbox lid on and run the filter you have until you put the exhaust on, then there are maps to accommodate your set up. I am running the stock PCV setup right now since I haven't installed my exhaust, intake with EHS outwears lid and GYTR intake. I know that the outwears/moflo airbox lid makes a big difference many years ago as I have a new Honda 400ex and put the lid on with jetting and it ran horrible so I had to remove it until I changed the jetting. However, in this case the fuel injection might be able to accommodate it, but I am not sure. I would be inclined to wait until you have a map that is a little closer to the setup before removing the lid. Tough call on this one as it might be fine since PCV richens up mapping from stock.
I was running lean with an FMF exhaust set up using the map they had on the site, I gave them a call yesterday and they've sent me a new FMF map.
Update dynojet sent me the same map that's on their site. Hopeless!!
