1 - 13 of 13 Posts
i started up my 03 660 today and noticed some smoke from the back end by the swingarm and figured it was melting snow, then i looked closer and saw i was getting slight smoke from where the spark plug is as well. So i shut her down and checked the oil and saw metal flakes mixed in with black material (have maybe 1hr on the new oil change). so i was seeing what is causing my problems
edit-smoke from the back has stopped but at the spark plug it still smokes, took it for a quick 2 minute ride and pulled the boot and it had what looked like condensation on it but smelled like gas
Not sure what you are asking of us.............
well i guess what im asking is what would be one of my main reasons for the gas smell/smoke coming from around the spark plug boot?, and the metal flakes, what are the odds those are just from being rough on the clutch? i changed the oil (whats it in there now) when i got it, the stuff before was pitch black.
Smoke or steam from around the plug is oil or water in the plug cavity... most likely unrelated to the flakes in your oil.
What was the bike's condition before you changed the oil?
Give a lot more detail on your bike, symptoms, timelines, etc., or it's going to be hard to decide what, if anything, is wrong.
the bike ran fine before i changed the oil, did it just because i didnt know how long since it had been done last, still starts up runs fine, no odd noises or anything that catches my eye/ear, since i changed the oil i have maybe put 2 hours on it.
How about some detail? How long have you had this bike?
sorry yeah, bought it back in november, i myself have barely had time to ride it. also flakes may be a bad word thinking about it now, i guess shavings would fit better. When i rubbed the dipstick on paper towel i could see what i would describe as "silver sand"
Try changing the oil and filter after the engine is hot to flush the contaminants from the engine, to see some contaminants in the oil is not unusual..............Excessive amounts are.................
Does your engine make any noticeable knocking or tapping noises. It might be hard to hear if you have an exhaust, get your ear close to the motor/cases... And definitely get a magnetic oil plug to catch those metal shavings!!
So is this the first time you've changed oil since getting it?
yea i changed it about a week after i got it and haven't put many hours on it since then, but ill change it again and check the filter when i do to see what the inside of that looks like
See what the next oil looks like before getting too concerned.
1 - 13 of 13 Posts
