hi got a raptor 350 with top end missing. i have all parts now having problem figuring out
what holds cam chain in guide in place the one exhaust side in place it seems to want too fall down into crank case can some one help Thanks
Hi there, have you looked at any on line OEM schematics to compare what you have vs what you need?
I'm not sure if this helps, on a Raptor 700 one side is bolted in the bottom of the case, The other side has a notch in the top of the cylinder and is held in place by the head.
WELCOME to the forum.
