just purchased the long mixture screw and the original was 3 turns out from full in, when it is adjusted out are you leaning or making it richer, im getting a back fire out the exhaust when i rap the throttle, but i do have the filter off so it is getting a little more air than normal .is it lean or rich which way do i adjust mixture screw,in or out, maybe need to rejet
Turn the screw out for more fuel..............
im guessing you have to rejet..the mixture screws are for idle only...try adjusting your needles.
