Does anyone know the stock settings of the mixture screw for an 07' 350?
Im pretty sure once it's all the way in its three full turns out.Depending on were you live or whats done to it you may have to tweak it a quater one way or the other. :thumbsup:
The way you adjust it for your bike is to turn the screw all the way in. Turn it out about 1 turn so the bike will start, now slowly turn the screw out. The idle will smooth out and start to pick up. You want to stop where the idle is at its smoothest, fastest rate. As soon as you notice the idle to slow down a little just back the screw up wo where it was idling the fastest and you are set.
If you have to go more than 4 turns you need to go up one on your pilot jet and do it again.
i dont no where to find the screw. dumb question huh but any ways if you could explain where it is
it will be appreciated.
it's in the very front of the carb in the middle...if you can turn your carb a little bit to the side you will see it!!
Thanks that helps alot. :thumbsup:
Also on some of the 2006 and newer the air screw is covered by a brass plug. Simply drill a very small hole in it and thread a sheet metal screw into it and pull it out.
