1 - 20 of 30 Posts
what is the best mods (starting with first to last) for a bone stock 2001?
do you have a budget?
yes prally around $100 a month
HV porting.....
686cc........
Hotrod connecting rod.........
Curtis exhaust..........
FCR carbs...........35mm..........
3 plughead..........
DYNA fs CDI.......
HD clutch springs..............
:D
ok willy lets take it one step at a time lol
well, if you have not touched a thing on it, open the air box, and re jet! saving your pennies to buy an exhaust.
Buy my 686 with stage 2 cam for 600. That's what I would do. Lol
1) put a full aftermarket exhaust system on
2) open the air box, add K&N or equivalent filter
3) jet accordingly
THis is called the 'big three' and will give you significantly more power over stock at a cost between $300 and $600 with some patience and luck.
THEN, when you're used to these improvements, (6 months to a year from now) come back and ask for what should be next... we'll tell you then. Your current question is way too open ended... you'll understand in 6 months.
~~~ 660 Specialist ~~~
3) jet accordingly
+1...:thumbsup:....like QuadManiac said this will deff make a diff from stock and shouldnt cost tht much if u do some searching in the for sale section
Save your money for when the one-way clutch goes, then save your money for when the transmission goes.
After that year is over with, throw some yfz/700 shocks on the front and follow up with a pipe, intake and some jets and just enjoy the ride.
oh yea he did say 01 huh....:eek:....and yes I too had to replace my one way, the L&A I put in worked great never had another problem.....I had to replace my stator too, as many have
lowsbody and qcraptor, even with a 700 the OP wouldn't be satisfied. Case in point, your respective mod plans and current mods to your 700's ;)
The Moose Rider
Touche. Yet this coming from a 660 guy gone 700. Oh wait you do still have a 660. Is it still in pieces? :p
I got a 01, what goes wrong with the transmission and clutch?? :eek:
The one way starter clutch goes bad on most of the 660's. It is not a cheap fix. I replace mine early before I had a problem with them. Still $150 or so but you have to pay to play.
The 01 trannys have a bad design and 2nd gear goes bad in them more often then the other trans(02-05)
Whats it mean by "one way"?
1 - 20 of 30 Posts
