G
What kind of hp ratings does most of yall see running the 3 mods and 11.1 compression pistons.
11:1 should push a high forty hp sheet. You will probably want to look at a cam to feed it right though.
A true rear wheel hp dyno will most likely show low-maybe mid 50's.....this is done using slicks, which is the only way to get an accurate number. Knobbies are not something you want to run on the dyno if your looking for "accurate" info :thumbsup:
