101 - 109 of 109 Posts
Discussion Starter #101
Discussion Starter #102
I was suspecting the intake because i noticed a huge gain with my exhaust. But, i think your intake would be fine
I did notice a gain but I guess maybe I was just expecting turbo gain type power.
Really considering a turbo.....
Discussion Starter #103
So all the air tubing to the engine is the same its just basically an added piece to put a clamp on filter right? So what I have is fine?
Yes I would and do run what you have. You can spend 2-300 for one that goes all the way to the throttle body. Not worth it if you ask me.
Discussion Starter #106
So I have the air box lid off right now, but in winter I might want to do some snow spinning and ill want the air box on, so im wondering if I can upload a separate map for my commander so I can switch between lid and no lid
You can have several maps on your laptop then you would have to download which map you want to the pcv. You can have 2 maps loaded in the pcv but you would need to wire in a on off switch to toggle between them. I have a switch for mine but use it for my auto tune.
The MSD blaster can have up to 10 maps loaded on it and switch between them by just turning a dial on the unit
Cool. I went pcv cause I also got the auto tune. So I can tune to the AFR I choose.
