Matt,MONSTERMATT said:how involved was the dr d install? it says on my directions i have to remove the skid plate- hope not
I have my front plastic off so I will shoot a pic of how I did mine. The hole in the fender is tapered so you have to make some sort of shim.capt_ron said:i moved my reverse to the handle bars with the drd switch
now i want my key in the hole with the fender and wanted to see how others mounted it
i just got fast flex bar so i need to get it moved thanks
Man O man... how about washing that pig???Hippy said:I made it :thumbsup:
LMAOfrankhkp7 said:Man O man... how about washing that pig???Hippy said:I made it :thumbsup:![]()
ps...I like the flex bars!
BJH - Did these bar mounts bolt right on to the stock stem? Any issues? I read a horror story of someone having to replace the steering stem to accommodate the Fasst bars but I am wondering if they made a bad choice when choosing bar clamps. I wonder if they bought a bar clamp that didn't work with the stock stem.BJH said:Trail Tech makes a bar clamp / key console that may eliminate the need to move the switch. They have models to fit bot 7/8" and 1 1/8".
This one is for the 660 but they have one for the 700 too.
