1 - 15 of 15 Posts
Basket, hub, everything. Where and what is a good one to buy? Definitely not spending a fortune, Not a race bike, just stock trail junk. But I will not put OE back in. Thanks
If you don't want to spend a lot and aren't going to go oem, try eBay for some used billet stuff.
Why are you set against oem stuff?
Discussion Starter #3
Clutch was fried when I got this thing with 27 hours, so I chalked it up to being because the shitty half fiber. After that I did a new clutch and now I believe the basket is grooved cause when engine is cold, it lurches forward and dies about 5 times.
The gytr stuff on ebay is ridiculously priced. I'm looking at almost $700 for the basket, hub, and boss... Does that sound right?
At 27 hours of stockish power, it's either poor adjustment or bad rider technique.
When oil is cold, there is drag, bike will try to lurch a bit.
And yes, the billet stuff, gytr Hinson and such is all very expensive.
Discussion Starter #5
Last time I rode it I let it idle for 15 mins and feathered the clutch a bit and it lurched forward 3 times and died each time. Clutch it maxed out also.
Discussion Starter #6
Alright, a buddy of mine is sending me his basket off his 450 but I'd need to re rivet my gear onto it. I can't find the rivets anywhere. Any idea?
I went through this on my 660, I don't think you can reliably re-attach the gear to a stock basket. If your basket isn't salvageable, your best options are an aftermarket billet basket, or try to find a good used stock one complete with ring gear.
If it's not grooved too bad, file them out.
I suppose it's possible. Haven't ran into that yet.
Now I'm confused, are you buying parts before taking the thing apart?
Discussion Starter #10
The basket is free. I just don't want this thing down for weeks so I'm kind of prepping. That's all.
I know when I put the clutch in @27 hrs the basket was starting to show signs of grooves. Ever since then the lurching only got worse. Now I think the actual fibers are toast since my clutch is fully adjusted out with barely 1/2 inch til full engagement.
You didn't clean up the basket before you put the new clutch in?
No, I honestly didn't even know that was a thing
I learned it the hard way too.
Lucky for me, it was on a yfz, so a clutch change is done easily in a half hour.
Discussion Starter #14
So update. Pulled it apart. And found nothing wrong.
Again..
So raptor has always had a clutch problem. When you first start it and put it into gear it would lurch forward and die. Do that 2-3 times and it's fine. I'd even sit there idling and pull clutch to try to get the plates to free up. We figured it was grooves in the basket. Well since then I've had to adjust the clutch, like way out, like it's got maybe 1/2 inch of slack til full engagement. Figured clutches toasted. Pulled it all apart and the basket and clutches are fine. Fibers are perfect. The fibers on top were dry as a bone though. It hasn't been run in a month. Not sure what to do now
Sounds like its just out of adjustment to me. Are you making clutch adjustments on the handlebars, or on the other end of the cable mounted on the clutch cover? If its maxed out in both places then maybe just need a new cable. Also soak those clutch plates in oil for a while before you re-install.
1 - 15 of 15 Posts
