Over the weekend we were riding trails and all of a sudden my 03' Raptor died and would not start turning turning nothing checked spark its there but nothing. Pulled starting it caused the engine to turn but not ignition. Can't figure it out . Anyone have any idea cdi? coil? anyone.
You can test each one of those components you mentioned. Make sure your carbs are sealed to the engine and your electrical connections are all good.
Just a couple things to check, I'm not saying you are stupid or anything, I've done these a few times...
Gas is turned on (and you have gas in the tank)
Run switch is on
Key is turned to the right
remove your inspection screws on crank/cam to varify cam is still on time/turning almost sounds like you snaped a chain
typical no-start procedure
Fuel delivery
spark
timing
