Hello,
Newbie here and need help. I have a 2003 660 that will run great for about 5-10 minutes then starts popping and back firing, then dies. It will start up and run fine again after about 5 minutes then start popping and dies again. What is going on? Thanks in advance!
Hello,
Check for a plugged vent line on the fuel cap or a plugged in tank fuel filter..........:)
thanks for your quick response! I did check those and they are both fine. What else can cause it to die after a few minutes riding then be fine after sitting for 5 minutes.
Possible Coil problem..............:)
