1 - 9 of 9 Posts
i cant get this gear off on the top right of the pic :mad: :mad: it has a little clip
but how do i get it off it's a bitch to get off i need some advice
thanks
eric :thumbsup: :thumbsup: :thumbsup:
Discussion Starter · #2 ·
well i got it off
now i have another question how do i get the this bolt off.
every time i turn it the whole flywheel turns with it, i dont have an impact
and i dont know what a strap wrench is.
i put it in first gear but the flywheel still shifs.
pics below i have all week to get this done so i am taking my time
thanks
eric
You need a strap wrench. it wont let it turn...
You might need someone to hold the brake, put it in gear, and you have to use the strap wrench.
where can i get a strap wrench and do u have any pics of what one look like
you can pull the clutch cover and put a thick aluminium wire between the countershaft gear and the crank gear. You haven't gotten to the good part yet, getting the nut off is easy compared to getting the flywheel off.
dont i need a sears puller to get the flywheel off
CoalShedRacing said:
the craftsman puller works well but you'll need to buy some longer grade 8 bolts and some good washers
ok thanks
well i finally got the one way off after 2 crafsman puller and a few snapped bolt
s it's off
1 - 9 of 9 Posts
